UV Editor: Save to Bitmap Request
In the UV Editor, I use the _Picture command to insert images and create a UV texture map. The Save to Bitmap feature is limited to 1024×1024 resolution ; my request is to make this optional, similar to Print, so we can export hi-res textures
Hi Seg,
I’ve added it here for the developers RH-96965 UVEditor: Add resolution option to Save to Bitmap
Thanks for reporting
