Negative scaling leads to an internal error:
The mapping channel riddle is still there, I hoped for an enhancement in this respect.
Thanks @Charles
I will check if there is a real problem with negative scaling.
Logged as RH-77179 UV Editor: negative scaling causing internal errors
Hi @Charles ,
The new Add button in the Materials panel is a UI change to unify how add icons look in different panels. You can alternately right click in the thumbnail area of the panel to create a new material from a context menu.
WCS mapping of textures in library materials will provide a real world unit size of the textures based on the model scale. In many cases this produces a better result by default than the surface divisions in a polysurface or the specific parametrization of those surfaces. You are correct that you need to know this to understand whatās happening and to change it. One small change we made back in Rhino 7 was to include a message with a text button in the Properties panel > Texture Mapping settings at the top. This allows you to click once to change the mapping for all textures in the material assigned to the selection at once from WCS to Channel 1. This may prove easier than manually changing each in materials that have more than one texture map.
Hi @BrianJ
I understand.
This can be really helpful.
My observation is that it works best when the model is in Inch, in Europe we use decimal units except UK.
So we always have to adjust.
Which is ok so far.
When I made the video, I wanted to point out the scaling issue, but couldnāt hold back the comments on the mapping.
You made a wonderful video on mapping for V6:
If you could make a new video for V8, it would be even more wonderful.
Mapping is complicatedā¦
@Charles Thanks! Iāll definitely make more mapping tutorials for Rhino 8, the UVeditor has been improved in many ways thanks to @Jussi_Aaltonen
I made one for Rhino 7 too if you havenāt seen it in the meantimeā¦
@BrianJ
I didnāt know the V7 videoā¦ Looking forward to the V8 āupdateā
At least some of the new features are not translated.
This is an example only:
Befehl: -_UVEditor
Mapping-Kanal <1>: 1
1 offen Polygonnetz der Auswahl hinzugefĆ¼gt.
Strg drĆ¼cken, um zu extrudieren, Alt-Taste antippen, um ein Duplikat zu erstellen
1 offen Kurve der Auswahl hinzugefĆ¼gt.
1 geschlossen FlƤchenverband der Auswahl hinzugefĆ¼gt.
Select edges to straighten
Select edges to straighten. Eingabetaste drĆ¼cken, wenn fertig
Objekte ziehen, Alt klicken um ein Duplikat zu erstellen
Select texture mesh edges to pin.
38 Polygonnetzkanten der Auswahl hinzugefĆ¼gt.
Select texture mesh edges to pinā¦ Eingabetaste drĆ¼cken, wenn fertig
Select closed curve near the edge chain pick location ( Distribution=ArcLength Alignment=ByPickPoints )
Befehl: _CommandHistory
Seems this is resolved in 8.0.23267.17003.
Thank you @Charles
Looking into it.
RH-77179 is fixed in Rhino 8 Service Release 13
