I´m try to use the VisualArq Elements in a C# in Grasshopper. I want to automatically export the Geometry via Script however right know I first need do use VisualArq Explode in order to get GeometryBase which I can use in the script. I can’t really figure out the API documentation on the VisualArq website. Are there maybe some examples how to deal with VisualArq Elements in a C# Script?
My script right now looks like that (basically from Junichiro Horikawa):
private void RunScript(DataTree<GeometryBase> geometries, string filename, string directory, bool export, ref object A)
if(export){
var guids = new List<Guid>();
for(int i = 0; i < geometries.BranchCount; i++){
for(int n = 0; n < geometries.Branches[i].Count; n++){
var geom = geometries.Branches[i][n];
var guid = Rhino.RhinoDoc.ActiveDoc.Objects.Add(geom);
guids.Add(guid);
Rhino.RhinoDoc.ActiveDoc.Objects.Select(guids);
string filepath = Path.Combine(directory, filename);
string cmd = "_-Export " + "\"" + filepath + "\"" + " _Enter _Enter ";
Rhino.RhinoApp.RunScript(cmd, false);
Rhino.RhinoDoc.ActiveDoc.Objects.Delete(guids, true);
