Hi.
I have breps. I wanted to select some of them with random tool. However, Now I want to play with the ones that I havent choose in these breps. Is there way?
Thank you for your consideration.
Hi.
I have took the breps into secondary list as a main list. Now, I believe by substracting sub-list from the main list, I will have access them. However, which command that I can use to substrate list from another list (List contains brep data)
Thank you for replying, it helps a lot. I have the same question in different position. I hope you can help again. In this time, I have surfaces and after I have use “Reduce” I want to use the one that I havent used. However, It doesnt work for this, how can i do it?
I hope, I can study more and pay you this back.
Appreciate it.
I appreciate it Kevin. You helped a lot. It was important for me… Thank you. I hope I can pay you this back…
