Hi there,
I need some help with using RhinoApp.RunScript in a c# component.
I am importing severall .dwgs from various windows folders as Blocks into Rhino
Code as following:
private void RunScript(DataTree<string> _files, bool _activate, ref object BlockName)
DataTree<string> nameTree = new DataTree<string>();
if(_activate)
for(int i = 0; i < _files.BranchCount; i++)
GH_Path path = new GH_Path(i);
for(int j = 0; j < _files.Branches[i].Count; j++)
string importFileName = _files.Branches[i][j];
var script = string.Format("_-Insert _File " + importFileName + " _Block _Enter 0 1 0", false);
RhinoApp.RunScript(script, false);
nameTree.Add(importFileName, path);
BlockName = nameTree;
return;
It does the job as it should, but after the import of all files, the GH canvas stalls, means I can zoom in and out, but no more editing is possible.
Any thoughts?
AddOn:
I would like to do delete the imported BlockInstance right afterwards, cause I just need the Block to work with.
Thx, Udo
EDIT:
If I use the BooleanToggle, instead of the Button, it works !?!
