Or using Grasshopper (or whatever else
I want to extract the name of a saved view applied to a Detail View. Is it possible? I’d rather also do it while not being inside the detail view.
Thanks!
Thanks!
my guess / did you try:
“detail” = DetailViewObject
→ viewport
→ name
yep…
Rhinocode / c# scripting in WIP
string name = detail.Viewport.Name;
hope this helps. kind regards -tom
using System;
using System.Diagnostics;
using Rhino.Input;
using Rhino.Commands;
using Rhino.DocObjects;
using Rhino;
const ObjectType filter = Rhino.DocObjects.ObjectType.Detail;
DetailViewObject detail = null;
ObjRef oref;
Result result = RhinoGet.GetOneObject("pick",false, filter, out oref );
if (oref == null) return;
detail = oref.Object() as DetailViewObject;
if (detail == null) return;
Console.WriteLine(name);
Works beautifully! Thanks so much!!
I’m going to try and make a plugin (someday) that automatically generates a view title. It will pull the view title as well as the scale from the detail view. Getting the scale (might) be easy because there’s already a field for that. We’ll see.
I’ve actually done a plugin for that. Will share it soon.
