Can you post a file that you’d like to render better? Also post a sample image of what you get now to describe the areas you wish to improve. I’ll give a try at setting it up…
Edit: I see you posted this Why is this render so grainy but I don’t have the file. Post a version with only a few of the floating pentagons and I’ll check it out.
It is particularly strange that both the walls and floor have the same material.
As fuse points out, there are no render options that allow you to tweak sampling levels or number of photons or anything like that. I mean, there are the two panes in render properties, but they don’t give much detailed control.
Ok. I think I’ve worked it out.
There was a point light at the same Z as the floor surface, when I moved it above the surface of the floor, the graininess disappeared.
My bad
cheers Peter
Geez, I was about to suggest checking for lights concurrent with surfaces at first, but my knowledge of rendering is so little I thought surely that would have been checked… Never have lights touching surfaces… One of the few things I do know…
