Would it be possible for McNeel to create “Use as viewer only” licence type or login option for Rhino? So you could setup Rhino install directly to work like expired evaluation version, without hassle, on any computer?
Our company needs few shop floor computers, that untrained (for cad work) workers could use to view rhino drawings and take measurements, etc. without accidentally ruining those drawings. Of course proper viewer version would be also ok.
Hi -
We are working on a viewer, iRhino, that works on iOS devices, but apart from that, we have no plans to create a viewer-only version that is otherwise the same as Rhino.
To use the iRhino WIP, see the following:
I think what Maakari would like is to be able to force Rhino evaluation into an expired state at installation rather than having to wait for the evaluation period to expire.
This certainly seems like it should be a very simple feature to add.
Remove the read-only attribute
Some read-only files can be changed to allow for edits by removing the read-only attribute in the file properties. Right-click the file and select Properties. Uncheck the box for Read-only and click OK
