Using Python to set the colour of the largest sphere
I’ve got a project that is going to require something like this:
It’s easy enough to find the radii of the spheres, but I’m not sure if there is a fairly straightforward way of separating the largest from the smallest then applying the colour.
Any pointers would be appreciated. In the meantime I’m going to keep trying.
Thanks,
Dan
Thought I had it. I’ll keep trying.
Hi Dan
On my phone so pseudo code
for id in spheres:
    radius = get_radius(id)
    if radius >= divide :
        rs.ObjectColor(id, large_color)
    else:
        rs.ObjectColor(id, small_color)
HTH
-Willem
Edit: I misread the question. If you want to find and colorize the largest only (and all the others different color) . You can color them all the smaller color and through @Dancergraham s sorting solution grab the largest and color that different.
Or if you have more than 2, put them in a list of tuples, then sort it:
mylist.append((radius, sphere_id))
mylist.sort()
largest = mylist[-1][1]
smallest = mylist[0][1]
Even better: largest = mylist.pop()[1] removes the final, largest item in the list and leaves all the rest so you can iterate through them. I like this solution because Python lists are optimised for quickly adding and removing items at the end.
Good one
Should that not be largest = mylist.pop(-1)[1]
Or am I missing something
-Willem
Either works actually! Pop() returns the tuple. Adding 1 or -1 takes the second (final) item from the tuple, ie the sphere itself :sunglasses:
I am being dense. Edited my answer already and edited again.
Does pop take the last item by default?
Yes, because lists are designed for LIFO access
Thanks guys. I’m going to take another look first thing in the morning. Looks like some good tips here.
Dan
Hi @Willem, @Dancergraham,
This worked well. I had overlooked the sort function and the pop suggestion was very helpful too.
Thanks for your help,
Dan
