Using pyserial with rhinopython.
I am trying to import serial but I am getting an error: No module named serial
Is there a way to using python libraries with rhinopython
I’ve never used pySerial before. I’m assuming it is this project
http://pyserial.sourceforge.net/
Looks like it should work with rhinopython. Make sure the library can be found on the path. Go to options in the “EditPythonScript” dialog to see the paths (or add more)
Yeah that is the library I am using.
I am trying it on rhinoMac which does not have the editpythonscript command
when I import should I include the full path of where the library is?
thanks
In that case I would try appending the path to pyserial like in the sample given here
http://www.johnny-lin.com/cdat_tips/tips_pylang/path.html
have you solved the problem with pyserial?
Becouse i?m trying to use pyserial but not work, I still have the Message: No module named serial…
any help will be precious
thanks
This is the code that I try to use:
import serial
import time
import sys
sys.path.append(“C:\Python27\Lib\site-packages”)
ser = serial.Serial(’/dev/tty.usbmodem411’, 9600)
counter = 1000
c = []
i=0
while True:
if i<counter:
stri = ser.readline()
#stri = "50,60,30"
c = stri.split(",")
for i in range(0,3):
c[i] = int(c[i])
print c
else:
break
counter +=1
I haven’t tested, but you will definitely need to append to the path before you attempt to import serial.
