Using millipede in mm
Just a question regarding the millipede plugin for GH, is it only usable in meters?
I’m using Mantis Shrimp to pipe geometry from Dynamo so the units are in mm.
I will be doing some parametric optimizations. If millipede is only available in meters, any tips?
Would scaling the geometry down by 1000, then using that as input for millipede work?
Do I need to set the Rhino units to meters?
