In the latest Rhino 8 WIP, the C# scripting component doesn’t seem like recognizing the ‘using’ statement complaining about the missing reference.
fresh installation might help do you think?
Hi @woojsung,
I just noticed your running on a Mac. Does this work in V7? Can you run the SystemInfo command and post the results?
— Dale
Oh. Right I am on a Mac, it works fine on v7
2022년 4월 28일 (목) 오전 11:05, Dale Fugier via McNeel Forum <mcneel@discoursemail.com>님이 작성:
In the Rhino WIP, please run the SystemInfo
command and post the results.
— Dale
Here you are. Thank you.
If you can take a look at the new C# scripting component’s copy and paste issue (doesn’t work) that would be great!
Rhino 8 SR0 2022-4-26 (Rhino WIP, 8.0.22116.12306, Git hash:master @ 03d671c58e622c1af59c363b7c31025cf8e0f70b)
License type: Commercial, build 2022-04-26
License details: Cloud Zoo
Expires on: 2022-06-10
Apple macOS Version 12.3.1 (Build 21E258) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro16,4
Language: en-KR (MacOS default)
AMD Radeon Pro 5600M OpenGL Engine (OpenGL ver:4.1 ATI-4.8.15)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 8176 MB
Graphics: AMD Radeon Pro 5600M
Displays: Color LCD (264dpi 2x), U3277WB (219dpi 2x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5600M (8 GB)
Color LCD (1792 x 1120 @ 59.00Hz)
U3277WB (3008 x 1692 @ 60.00Hz)
USB devices
VLI Inc.: USB 2.0 BILLBOARD
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
com.intel.driver.EnergyDriver (3.7.0) 35E739F9-BF6C-3024-A67C-750711B3FB64
com.CalDigit.ThunderboltStationChargingSupport (1.2) 93581301-3B34-39B8-803B-E2F733B2D0D1
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Users/woojsung/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Twinmotion Direct Link 2020.2.rhp “Twinmotion Direct Link 2020” 1.0.6.0
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.22116.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRoslyn.rhp “RhinoRoslyn” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/PlugIns/Constraints.rhp “Constraints” 8.0.22116.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ConstraintsUI.rhp “Constraints UI” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.22116.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.22116.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCPython.rhp “RhinoCPython” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.22116.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.22116.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.22116.12306
Hi @woojsung,
I can repeat this - I’ve logged the issue.
https://mcneel.myjetbrains.com/youtrack/issue/RH-68472
Thanks,
– Dale
Thanks for the reply. However, Linq still doesn’t work. Please see attached.
I am on Version 8 WIP (8.0.22130.14236, 2022-05-10) updated just now.
Also, line number reporting doesn’t work reporting incorrect numbers, and most importantly copy and paste in the editor doesn’t work. Any chance to use dark mode in the editor?
Thanks,
That is not a problem with LINQ. You need to add using System.Collections.Generic
so you can use List<>
Yes, sorry, I just realized it myself. After a bit of testing it looks like the SQL-like syntax works just fine:
@curtisw any idea why the extension methods from LINQ don’t work? They don’t even autocomplete when typing code. Maybe missing an assembly reference for collections to have these work?
No worries. I think the issue is with ToList()
. Please see attached. Thanks,
Also as it is really important to me, could you please take a look at the other issues with the new code editor?
Quite possible. But it should still work (: In this particular case you indeed don’t need it, sorting works without the ToList()
just fine.
That’s right. But sometimes I need to use the method in Linq, which is problematic with many existing codes.
Could someone please take a look at this?
Also, again, the other issues with the new code editor should receive more love.
Yes, that’s the problem. Thanks
@woojsung
All these other issues are being worked on and will be fixed soon.
Thanks for the feedback.
