Hey everyone,
I want to develop a workflow where I could have hatch patterns as input and use them in Compute.
The current status is that you can’t internalize Model Hatch Patterns in GH, so a workaround I came up with is to assign the desired pattern to a Hatch, and internalise that instead, then extract the parameters and reapply them as desired. Here’s an example:
test_hatch.gh (20.5 KB)
The last code segment is designed to visualize the hatch pattern in a webapp. However, the pattern curves don’t seem to be computed on a local appserver, only the test line goes through. I get the following errors:
I assume the hatch info is somewhat internalized when used in GH but doesn’t translate in Compute (?)
Any ideas how to get around this?
Thanks,
Abdo.
