ALSO: one other problem I am having, In star-maker, how could this variable exist:
ratio_offset_even
it is only in the function
def UpdateTempCurves(self, ratio_offset_even, ratio_offset_odd):
but when this function is called, there is no variable passed to it (line 15):
dialog.SetValueChangedCallback(self.UpdateTempCurves)
the class is here:
class SliderFormController():
""“Hook up UI of the SliderForm with some Rhino specific actions”""
def __init__(self, curve_ids, dialog):
# tell the SliderForm about a function to call when the slider values change
# Set up display conduit events to allow drawing of temporary preview
# geometry while the values are being adjusted by the user
# CalculateBoundingBox event is used to adjust the view's clipped bounds.
# Preview geometry may be outside the area of the bounding box of geometry
# in the document and therefore may be clipped if we don't adjust the bbox
Rhino.Display.DisplayPipeline.CalculateBoundingBox += self.OnCalcBoundingBox
# DrawForeground event is used to actually draw some temporary geometry on top
# of everything else. Depth writing/testing are off at this stage so all
# geometry is drawn on top
Rhino.Display.DisplayPipeline.DrawForeground += self.OnDrawForeground
# Get notified of when the form closes so we can remove our conduits
dialog.FormClosed += self.OnSliderFormClosed
# temp_curves and temp_curves_bbox are used for dynamic display
self.__temp_curves = []
self.__temp_curves_bbox = None
# original_curves is a list of (id, centroid, points) for each curve
# provided in the constructor. This is the information we need to
# quickly construct our temp_curves
self.__original_curves = []
for curve_id in curve_ids:
# curve_id is a Guid. Try to get the Curve geometry from this Guid
objref = Rhino.DocObjects.ObjRef(curve_id)
curve_geometry = objref.Curve()
objref.Dispose()
if( curve_geometry!=None and curve_geometry.IsClosed ):
mp = Rhino.Geometry.AreaMassProperties.Compute(curve_geometry)
rc, points = curve_geometry.TryGetPolyline()
if( rc ): self.__original_curves.append( (curve_id, mp.Centroid, points) )
def OnSliderFormClosed(self, sender, e):
# Form has closed. Remove our display conduit
Rhino.Display.DisplayPipeline.DrawForeground -= self.OnDrawForeground
Rhino.Display.DisplayPipeline.CalculateBoundingBox -= self.OnCalcBoundingBox
scriptcontext.doc.Views.Redraw()
def OnDrawForeground(self, sender, e):
# This function is called while updating viewports. Try not to perform
# too many calculations in here to minimize display performance hit.
# Draw each temp_curve in red and a "control" polygon in feedback color
curve_color = System.Drawing.Color.Red
feedback_color = Rhino.ApplicationSettings.AppearanceSettings.FeedbackColor
for points, curve in self.__temp_curves:
e.Display.DrawCurve(curve, curve_color, 1)
e.Display.DrawDottedPolyline( points, feedback_color, True )
e.Display.DrawPoints(points, Rhino.Display.PointStyle.ControlPoint, 2, feedback_color)
def OnCalcBoundingBox(self, sender, e):
# Update the boundingbox to include our temporary curves
if(self.__temp_curves_bbox!=None):
e.IncludeBoundingBox(self.__temp_curves_bbox)
self.__temp_curves_bbox=None
for id, centroid, cvs in self.__original_curves:
# "cook" up a temp_curve from the original curve data
temp_points = []
count = len(cvs)
for index, cv in enumerate(cvs):
vector = cv - centroid
# use %2 for even/odd test
if( index%2 == 0 or index==(count-1)):
vector *= ratio_offset_even
else:
vector *= ratio_offset_odd
point = centroid + vector
temp_points.append(point)
temp_curve = Rhino.Geometry.Curve.CreateControlPointCurve(temp_points, 3)
if( temp_curve!=None ):
self.__temp_curves.append((temp_points,temp_curve))
if( self.__temp_curves_bbox==None ):
self.__temp_curves_bbox = temp_curve.GetBoundingBox(False)
else:
self.__temp_curves_bbox = Rhino.Geometry.BoundingBox.Union( self.__temp_curves_bbox, temp_curve.GetBoundingBox(False))
def AddCurvesToDocument(self):
# add the temp_curves to the document so they become "real" Rhino geometry
scriptcontext.doc.Objects.AddCurve(curve)
