try typing Blend whatever then use ESC, results in a minute long spinball every time.
this started happening (again) in the last few updates, its pretty unbearable please fix it soon.
Must be a Mac problem, not happening in Windows WIP here.
I can’t reproduce this on macOS.
not using any WIP here, just the regular version for mac.
in the WIP for mac it also works normal.
i am using Mac OS Tahoe 26.2
Rhino Version 8 (8.28.26013.10002, 2026-01-13)
its a bit strange.. recently there bugs happening and being reported which nobody can reproduce. i am thinking if you guys have the same versions as we? or do you always use internal builds?
macOS Tahoe 26.2 here as well.
Now tested on (8.28.26005.18002, 2026-01-05) without luck.
For my job, it usually doesn’t make much sense testing outdated versions.
do you have the command line integrated into the left sidebar?
well i switched layouts around a bit then it got less and less and suddenly it stopped messing around.. for a while till i restarted. then it started again.
Yes I’m seeing this also in 8.28.26012.06002 on an M1 running 26.0.1
RH-91493 BeachBall when trying to escape a command
RH-91493 is fixed in Rhino 8 Service Release 27
