Hi! another question that is slightly related, I used the “model object” node in order apply the draw order to a hatch. It works well in model space, but if I use a source curve in paperspace, the hatch is still added into model space instead of where the source curve is. Is there another node I should be using to apply the draw order?
Good question. I am not sure what limitations are in this with Draw order. @kike may be able to help here.
