Hi, I’m now trying to use my class that inherits GH_Param as Hops output.
I defined classes below,
- “Whisky” class
- “GHWhisky” class which inherits GH_Goo
- “Param_Whisky” class which inherits GH_Param
- “ConstructWhisky” component class which inherits GH_Component
And I cloned Compute.rhino3d Repository, added codes about my classes in all parts that switches behavior depending on passed type in compute.geometry and Hops projects.
As a result, Hops can recognize my Param_Whisky as output and add output port to Hops Component, but returns null.
As I debugged, compute.geometry server seems to return null as Value in VolatileData in Param_Whisky.
Do I have to override some Interfaces or methods or modify other parts in compute.geometry?
Thanks in advance,
public class Whisky
public Whisky()
public Whisky(string name, int distilledYear, int matureYear, string distillerName, string bottlerName)
Name = name;
DistilledYear = distilledYear;
MatureYear = matureYear;
DistillerName = distillerName;
BottlerName = bottlerName;
public string Name { get; set; }
public int DistilledYear { get; set; }
public int MatureYear { get; set; }
public string DistillerName { get; set; }
public string BottlerName { get; set; }
public bool IsBottlers => DistillerName == BottlerName;
public class GHWhisky : GH_Goo<Whisky>
public GHWhisky(GH_Goo<Whisky> other) : base(other)
Value = other.Value;
public GHWhisky()
public GHWhisky(Whisky internal_data) : base(internal_data)
Value = internal_data;
public override bool IsValid => !string.IsNullOrEmpty(Value.Name) && !string.IsNullOrEmpty(Value.DistillerName) && !string.IsNullOrEmpty(Value.BottlerName);
public override string TypeName => typeof(Whisky).Name;
public override string TypeDescription => "Whisky class for grasshopper.";
public override IGH_Goo Duplicate()
return new GHWhisky { Value = new Whisky { Name = Value.Name.Clone() as string, DistilledYear = Value.DistilledYear, MatureYear = Value.MatureYear, BottlerName = Value.BottlerName.Clone() as string, DistillerName = Value.DistillerName.Clone() as string } };
public override string ToString()
return $"{Value.Name} {Value.MatureYear}yo, Bottled by {Value.BottlerName}, Distilled in {Value.DistilledYear} by {Value.DistillerName}";
public override bool CastFrom(object source)
switch (source)
case Whisky w:
this.Value = w;
return true;
default:
return false;
public override bool CastTo<Q>(ref Q target)
switch (target)
case Whisky w:
target = (Q)(object)Value;
return true;
default:
return false;
public class Param_Whisky : GH_Param<GHWhisky>
public Param_Whisky(string name, string nickname, string description, GH_ParamAccess access) : base(name, nickname, description, "", "", access)
public Param_Whisky() : base("Whisky", "W", "Whisky class", "HopsTest", "Param", GH_ParamAccess.tree)
public Param_Whisky(IGH_InstanceDescription tag) : base(tag)
public Param_Whisky(IGH_InstanceDescription tag, GH_ParamAccess access) : base(tag, access)
public override Guid ComponentGuid => new Guid("0f143222-e477-4d81-bba2-c6f0dce5b7e6");
public class ConstructWhisky : GH_Component
public ConstructWhisky() : base("ConstructWhisky", "CW", "", "HopsTest", "Construction")
public override Guid ComponentGuid => new Guid("8c394fe0-bee5-4f94-8296-c2b08d71db45");
protected override void RegisterInputParams(GH_InputParamManager pManager)
pManager.AddTextParameter("Name", "N", "", GH_ParamAccess.item);
pManager.AddIntegerParameter("MatureYear", "MY", "", GH_ParamAccess.item);
pManager.AddIntegerParameter("DiltilledYear", "DY", "", GH_ParamAccess.item);
pManager.AddTextParameter("DistillerName", "DN", "", GH_ParamAccess.item);
pManager.AddTextParameter("BottlerName", "BN", "", GH_ParamAccess.item);
pManager[4].Optional = true;
protected override void RegisterOutputParams(GH_OutputParamManager pManager)
pManager.AddParameter(new Param_Whisky("Whisky", "W", "", GH_ParamAccess.item));
protected override void SolveInstance(IGH_DataAccess DA)
string name = default;
int mYear = default;
int dYear = default;
string dName = default;
string bName = default;
if (!DA.GetData(0, ref name))
return;
if (!DA.GetData(1, ref mYear))
return;
if (!DA.GetData(2, ref dYear))
return;
if (!DA.GetData(3, ref dName))
return;
if (!DA.GetData(4, ref bName))
bName = dName;
DA.SetData(0, new Whisky(name, dYear, mYear, dName, bName));
