I’m trying to pass a brep object through a series of default grasshoppper nodes in C#, but I realized I also need to pass inputs to ClimateStudio nodes within the same program. Is this possible? I haven’t found any ClimateStudio API’s or any documentation that interfaces with RhinoCommon yet.
I do not know the answer but I passed this on to one of the CS developers so hopefully he can help more or point you in the right direction.
Thanks so much I appreciate it!
Did you hear back from the CS developers?
Hi Cooper,
No, but ill follow up.
Hi Remy,
Email just sent. Thanks!
Best,
Cooper
It’s not that open, the API. But there’s the climatestudiograsshopper and climatestudiocommon DLLs if I remember correctly.
Somehow I had issues inputting a home made CS object into the CS components. I found out using native CS components to create classes and then manipulate the instances is working.
See attached for inspiration
ClimateStudio.gh (62.1 KB)
I appreciate the help! I’ll take a look
Let us know how goes
