Using a pluging based on zoo without access to internet
I’m developing a plugin on c++ that use zoo to check the licence ,once i insert the serial key it’s ok zoo plugin dont ask me again for the serial , but once i’m not connected to internet it request a serial key because he is doing the check every time my pluging is load.
my question is there is a way to disable this check every time?
Thanks
The Zoo licensing system supports two types of licenses: 1.) Standalone and 2.) Network.
If your plug-in is configured to use network license, then it will always request a license from a Zoo server.
If you don’t want your plug-in getting licenses from the Zoo, then configure your plug-in to use Standalone licensing.
Now, if you are on a laptop and you take it some place were there is no internet connection, then you should check out a license from the Zoo before doing so. You can do this by clicking Tools > Options > Licenses.
Does this help?
– Dale
I’m developing a plug-in that use a standalone license system , so can i disable this check ?
If you want to run as standalone, then when asked for a license click the Enter a License button. For example:
You can switch between standalone and networking licensing using the Licenses page in Options.
– Dale
Dear @dale
thanks for all the information provided here:
https://github.com/mcneel/Zoo5
How is this Standalone-Configuration done ?
Can i use the Zoo-Licence System just to store my own licence-Information locally
(and therefore do not need to worry about user privileges (read / write), the place where to store it, and so on…)
The LicenseData Class does not Provide a Property for this
StandaloneLicence = Standalone;
Also the Plugin Itself does not have a Property
RequiredLicenceType = Standalone;
what Do i miss ?
Best
Tom
Yes
The Zoo licensing system does not restrict licenses types to be either standalone or network. This gives the user/administrator the flexibility to install the license where they see fit.
– Dale
2 posts were split to a new topic: Zoo and Laptop question
