I’m trying to set and get user strings on the objects, but something is going wrong.
First I create surface and apply user strings:
var srf = NurbsSurface.CreateFromPoints(point3dList, count, count, 1, 1);
srf.SetUserString(“test1”, “1”);
Then I get the user string successfully:
//get all objects from rhino
ObjRef refSurf = new ObjRef(rhino_object.Id);
var getData = refSurf.Brep().face.Faces[0].UnderlyingSurface().GetUserString(“test1”);
but when I modify object by moving node, and try to get its string again, I get no strings on the object. What could be wrong? After modifying string I select object by hand.
