is there a way to make the following keyboard shortcut work without a script? Via scripting I know how to do it. Need it for a simple org. wide setup. %userprofile% is not resolved.
I guess the problem is New always brings you to the current template folder - if there is a different folder that you want to use, then users can set that folder as the template folder and -New Browse should go there, I’d think - but in a general way, I do not see how to do this in a macro - not that you can’t I just do not see it, yet at least.
thanks for the great support. I’ll make a Python command. That’s the easiest way to distribute since we have a Python based office plugin anyways. @nathanletwory : Do you know if the following works cross platform?
