Hi there,
Let say I’ve two objects: each one has an UserKey “param” with different values for each objects:
If I select the two objects, the “Value” field will then the display “(varies)”, which is OK (same behaviour than the “Display Color” or “Name” field for example):
But if I accidentally double-click on that field (without necessarily specifying a new value for both objects), all the values will then be replaced by the “(varies)” string:
The “Name” field don’t behave this way: the original objects names are “protected” until a new value is typed in the field.
