UserDictionary question
I would like to ask what is the difference between these two lines?
            object_attributes.UserDictionary.Set("cut", cut);
            object_attributes.SetUserString("cut", cut);
And should I attach string to object attributes or objects themeselves?
Hi @Petras1,
The former is an ArchivableDictionary, which is implemented in RhinoCommon.
The latter is a string dictionary implemented in openNURBS.
Yes, object attributes. Data attached here tends to survive better, when compared to attaching to geometry.
– Dale
Thank you
