User String Attributes and CTRL+Z
I am running the following method to delete specific user string attributes:
    def clear_features(self):
        for key in self.geometry_plane[0].Attributes.GetUserStrings():
            if "feature" in key:
                self.geometry_plane[0].Attributes.DeleteUserString(key)
        self.geometry_plane[0].CommitChanges()
It works but I cannot go back and CTRL+Z does not bring the attributes back.
Is there a way to enable “history” for user attributes?
there are snippets and examples (c#) that use doc.Objects.ModifyAttributes instead of commit change…
// Make a copy of the object's attributes
    var attributes = rhObject.Attributes.Duplicate();
    // Attach our user data
    attributes.UserData.Add(userData);
    // Modify the object's attributes
    doc.Objects.ModifyAttributes(rhObject, attributes, false);
same approach in this sample
var attributes = obj.Attributes.Duplicate();
          attributes.SetUserString(SampleStringData.Key, SampleStringData.Value);
          doc.Objects.ModifyAttributes(objref, attributes, false);
but i have not tested if this makes any difference then CommitChanges()… worth trying I think.
I hope i interpreted correct - you want to support undo - not history ?
kind regards - tom
Works like a charm, thank you very much:
        attributes = self.geometry_plane[0].Attributes.Duplicate()
        for key in attributes.GetUserStrings():
                attributes.DeleteUserString(key)
        Rhino.RhinoDoc.ActiveDoc.Objects.ModifyAttributes(self.geometry_plane[0], attributes, False)
