Those any one know how to call a String obtained by another function?
I created some planes in a Sub, now on other Sub I want to call that plane to use for intersection.
Problem is I don’t know how to reference the string in a different Sub
for exemple
Call Planes
Sub Planes
Dim point1, point2, point3, point4, Plane1
point1 = rhino.addpoint(0,0,0)
point2 = rhino.addpoint(10,10,0)
point3 = rhino.addpoint(-10,-10,0)
point4 = rhino.addpoint(-10,10,0)
plane1 = rhino.addsurface(point1, point2, point3, poin4)
End Sub
Call section
sub section
dim Plane1
How do I call the Plane1??
endsub
thanks everyone
will help me alot organize this script which is all in 1 Sub
pascal
(Pascal Golay)
July 23, 2013, 3:28pm
2
Hello- instead of making the plane in a sub, make it a function that returns the plane as its result:
Function MakePlane()
blah blah
MakePlane = rhino.addsurface(point1, point2, point3, poin4)
End Function
Sub Section
dim Plane1: Plane1 = MakePlane()
end sub
Nice, thanks.
Can I make more then 1 plane per function? how do I then call a specific plane then?
Or is just better to do 1 plane per function?
pascal
(Pascal Golay)
July 23, 2013, 4:06pm
4
You can make an array of planes and then access the array by index.
So, your function would build up an array
Function MakePlanes(Num)
dim i, arrPlanes
redim arrPlanes(num-1)
for i = 0 to num-1
blah blah
arrPlanes(i) = rhino.addsurface(point1, point2, point3, poin4)
Next
MakePlanes= arrPlanes
End Function
Sub Section
dim aPlanes: aPlanes = MakePlanes(5)
dim Plane1: Plane1 = aPlanes(0)
dim Plane2: Plane2 = aPlanes(1)
etc etc
End Sub
Cool, I see
Will give it a go, thanks so much for your help.
As always you guys kick ass!!!
