hey there,
I would like to use the “point on curve” modul in the human UI. How can it be done. So far I found no UI element that works.
hey there,
use a HUI slider from 0-1 and evaluate a reparameterized curve with its value
First thank you for your quick response . Unfortunately I was not able to build it. I am still not able to modify the parameter given by the “point on curve” through the HUI. I attached an example snipped of my graph. ( the part with updating the 3dview should be clear)
Hey Zsi48891,
Just like andheum mentioned, you just need to use a regular slider connected to a “evaluate curve”-component ( the curve has to be reparametrized (right-click on the input curve and select reparametrize to set the domain of the curve to 0 to 1 )).
With the UI components, you can change the slider and the point on your curve.
greetings,
Bumaye
