Use of material
Hi, I would like to ask if there is something that calculates the material consumption.
Like when I build square 1 by 1 it tells me that I’ve used 1m3 of material.
Thanks
Hans
When the objects are solids you can get their volume and calculate the weight from the specific gravity of each material
as @Jan12 said, use volume command:
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/volume.htm%3FTocPath%3DCommands|Alphabetical|V|_____14
