I find myself using the solid edit tools more and more. Is there a way to use the gumball when using the solid edit tools? It would be really useful for me to be able to not just move surfaces but also scale using the gumball and the move face command just to save a little time and speed up my workflow. Is this possible?
Yes. Gumball works on sub-objects (faces, edges, solid edit points) just the same as it does on main objects.
Just in case you don’t know, it’s ctrl+shift+click to select subobjects like faces and edges…
–Mitch
Thanks Mitch.
I knew the Rhino forum would know the answer
