Use Anemone?
Hi,guys.
I would like to create the following program.
· Acquire any point
· Get the largest number from surrounding points
· Go to that point
· Create a geometry from a point
It is an image like a maze algorithm.
I will attach a reference image below.
Thank you.
Can you attach the file ?
Thank you Mohamad !
I also consider using Ghpython.
What should I do?
growth.gh (44.7 KB)
You mean something like this?
Heiwayuuri.gh (27.8 KB)
WOW!
Thank you very much!
I will contact you again when I use it and I do not understand it!
Thank you Mahdiyar.
Here, I write it in C# , It’s a little messy but a good point to start:
Heiwayuuri.gh (21.8 KB)
Thank you Mahdiyar.
I’m really happy.
Why write C # rather than pytrhon?
I have used Unity myself, so I understand a bit.
I will ask again.
I have two questions.
Why is not the largest number selected only for the first processing? (I want to go to 72 instead of 70)
I would like to expand this process in three dimensions, how can I do it? (See image below)
Actually it starts from 72 and then goes to 98. I forgot to add the first point to the list of points.
You just need to give it a 3D grid of points:
Heiwayuuri.gh (21.4 KB)
It’s so cool! Thanks to you, I’m thinking of creating a new work.
If possible, can you create a file without script?
I think I can not control C #.
Thanks Mahdiyar.
I replicated your solution, and I found that the given start point could not be or near the first point of the point list produced by square grid, because when you feed “null” with “cull index” , the result equals to feeding “0” with it.
Is this a hidden bug of “cull index”?
