I have a SubD object and would like to use some of the surface curves as a guide to create some sweep objects. Thought for sure I’d done this before, but maybe not…
For example, I’d like to sweep a circle along the yellow path on the subD object here:
If this can’t be done… well, I tried creating a mesh out of the object and tried removing everything but the path I needed, and couldn’t delete the last set of control points:
Any suggestions appreciated!
