USD export: Base color not converted to linear
I’d like to ask about the brightness of the base color in a .usda file exported from Rhino 9.
Version: Rhino 9 BETA (9.0.26293.12303, 2026/10/20)
■ Attached files
  • CubeBaseColor.usda: Exported USD file
  • gray_1024x1024.png: Texture used in M_PBR_Texture (pixel value R=G=B=118)
  • rhino_viewport_materials.png: Rhino viewport and material settings
  • usdview_screenshot.png: Display in usdview
■ Steps to reproduce
I placed two MeshBoxes, X=1000, Y=2000, Z=3000 (mm), side by side and applied the following materials:
  • M_PBR_Value118 (left): Physically Based, base color R=G=B=118
  • M_PBR_Texture (right): Physically Based, base color set to a Bitmap Texture using gray_1024x1024.png (Treat as linear is not selected)
Export options:
  • Prim Settings
    • Default layer: Default
    • Model name: Cube
  • References
    • Block handling: Embedded
  • Data
    • Include user strings: checked
■ Issue
In Rhino’s Raytraced viewport, the two cubes appear almost equally bright (rhino_viewport_materials.png).
However, when CubeBaseColor.usda is opened in usdview, the left cube with M_PBR_Value118 appears noticeably brighter (usdview_screenshot.png).
■ Possible cause
M_PBR_Value118 is exported as diffuseColor = (0.4627451, 0.4627451, 0.4627451).
This is 118/255 written out as an sRGB value without conversion.
Since USD color3f values are treated as linear, usdview renders it as linear 0.463.
On the other hand, the texture is converted from sRGB to linear by UsdUVTexture, so 118 is rendered as approximately linear 0.181.
I believe the solid base color should also be converted from sRGB to linear on export (118 → approx. 0.181).
Could you please confirm?
I’d appreciate any insight on this.
CubeBaseColor.usda (6.0 KB)
Taka_K -
Your reading matches the USD spec: solid color values are treated as linear, while 8-bit textures get decoded from sRGB. I’ve logged this as RH-99963 so we can get it looked at.
Looks like the solid color needs to be color corrected. How these colors work in Rhino also depend on the gamma settings.
Thank you for confirming.
For reference, here are my Rendering settings (rhino_rendering_settings.png):
