Usability issue (Rhino 6 wip).
I design a generic curve. Then insert, for example, two points on the curve (I want to divide the curve in these two points).
Then I select the curve to do the split operation: I automatically activate the curve control points, which are confused with the two points chosen by me.
To avoid this I should either change the color to the points so that they do not confuse with the checkpoints or turn off the control points of a curve with the command.
I think that every time it is frustrating to do this.
Do I miss something?
