Hi, can’t find the window Texture Mapping on a block object. so it is impossible to manage texture with Vray
what is the best way ? unblock the objet ?
(The model is an exportation from ARCHICAD in 3dm), maybe there is an other solution ? OBJ ? STL?
Hi @emile_francois
Just to be sure: You can edit/open the block just by double clicking it, and then change the mapping as you see fit on the individual objects - and then click OK to leave block edit mode.
HTH, Jakob
