Urgent! Rhino 8 Gumball orientation completely randomized
-system information at the end.
I’ve taken a 3-ish month break from modelling and getting back into it, and have now found all of my models, including newly created ones entirely unusable because of this strange gumball issue that has randomly occured.
The issue is that all objects have entirely random gumball orientations. This includes old objects, in files as much as a year old (the oldest on my system), or entirely new objects. For most objects the gumball is simply adjusted, however, for objects from plugins like Vray, which I use a lot, they’re completely discombobulated.
The 5 following pictures are from a completely new file, with freshly created or imported objects.
-I have used a fresh installer to run Rhino Repair, Rhino Uninstall and Reinstall, this has not worked.
-I have uninstalled and reinstalled Vray for Rhino 8, this has not worked.
-GumballReset does not work.
-GumballRelocate DOES work, however, it’s not feasible to GumballRelocate every single object.
Other Information:
This bug does not happen to circular objects, cylinders, spheres, etc.
I have not edited, updated, installed or uninstalled any of these files to my understanding, besides copy and pasting them into a google drive. Even so, the original files are all facing this issue.
Help!!! This has been very frustrating, and I cannot find someone with a similar problem, and no fix seems to work.
Sample 3DM File:
Test Failure 4.3dm (359.6 KB)
SYSTEM INFO:
Rhino 8 SR28 2026-2-10 (Rhino 8, 8.28.26041.11001, Git hash:master @ b7874a05a6982d0419fcc4f6009b510b48a09cb3)
License type: Educational, build 2026-02-10
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.14
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1660 SUPER (NVidia) Memory: 6GB, Driver date: 12-30-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 591.74
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-30-2025
Driver Version: 32.0.15.9174
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.28.26041.11001
Thank you, in advance.
By the looks of it your Gumball is Object aligned instead of Cplane aligned. Your pictures don’t include the status bar so I can’t know for sure.
Check to what your gumball is aligned.
Maybe it’s aligned to the object and you want to align to the world
You have auto cplane on, make it not auto cplane
