Urgent Help with trying to fillet Rad a Motorcycle Brake Hub in Rhino 3
Please could someone help me with trying to fillet a 10mm rad in the areas with curves. I know it will dip into the job . This is what we are trying to acchieve.Brake-hub-new.3dm (2.4 MB)
did you get this working? I took a quick look. your surfaces are just messy is all. Clean up and trim and join open surfaces. make it all solid then use filletege. good luck!
This one was handled via tech@mcneel.com
