Hi everybody!! I’ll try to explain, with my poor english: I have to model the cover of a parfume bootle… so, I did a curve, square with rounded angle, and four curves for the curved surface … when the curve network is done, I have always the “ghost” of the corners, as “shrinks” on the surface, from each angle to the center… how to get a really smooth surface, but keeping the square “rounded” edge as a base??
Hi celmar - please post the curves, there is no good way to help without seeing what you’ve got.
thanks,
unfortunely, I don’t understand how to upload a picture… ???
Just drag and drop.
in fact, I have solved my problem by creating a flat curve surface, then rebuild, then gently drag the center control points up... But I should want to understand why, using network curve, I have these marked edges!!
Hi celmar - see the attached:
Pillow_PG.3dm (128.0 KB)
That is one way to get at this type of shape.
