Updated script
Dear all
I need help to updated the script Arrange Tiles.
I have one script to do arrange tiles but I need updated it you can help me in this point.
I used the file ze.3dm to explain you exactly what I need.
1º select the script Arrange the tiles.
2º Select the curves.
3º Rotated the curves axis X Yes.
4º Add point YES.
5º Left corner par enveloped.
6º Enveloped Withd I put 200.
7º Enveloped height I put 200.
8º Spacing I put 5.
9º I get the final result.
Blocked image
What I check is wrrong with the script is more than one part inside work place.
and this is not OK, what is necessary change to get only the correct tiles in teh work place?
I like do some change in the script.
I like not give the with and teh height of the envoloped but select one square.
8º Spacing I put 5.
arrange tiles.pdf (174.0 KB)I like have no spacing in the lateral of teh square but have only the spacing between the tiles all around the squares have spacing 0.
I like have not separated tiles and the the way (line to cut) but elements + points + line all in one curve.
Cloud you help me in this.
Best regards
jose
ze.3dm (157.3 KB)ArrangeTiles.rvb (11.1 KB)
[Dear all
4º Add point YES.
8º Spacing I put 5.
Blocked image
8º Spacing I put 5.
arrange tiles.pdf3 (174.0 KB)I like have no spacing in the lateral of teh square but have only the spacing between the tiles all around the squares have spacing 0.
Best regards
jose
ze.3dm2 (157.3 KB)ArrangeTiles
Hi Jose,
This category is for helping those who are writing scripts.
If you do not know how to to write scripts and you want somebody to help you create or modify a script, then you might consider posting in the Jobs & Portfolio’s category.
http://discourse.mcneel.com/c/jobs-portfolios
– Dale
