Updated script - Project Objects
Hey, Claude has done a bit of work on Pascal’s old Project Objects script, under my direction. I think it’s a bit less buggy and has 2 new useful features:
The first is a Depth option which lets you define how deep into the target your parts should go. This is especially useful so that you don’t need to use high resolutions when projecting. Instead, in many cases you can make your part overlap your target and trimming is easy.
The other great option is RedoExistingProjection, which lets you re-project objects. This lets you tweak the shape and location of the objects without having to delete and redo your projection. And it works well with the Depth option, so you can make changes and still have the same consistent part overlap.
This version works with subds, meshes, surfaces, and polysurfaces. In my testing, it works in Rhino 7, 8, and 9. I’ll attach the button graphic I use, too, in case anyone wants it.
ProjectObjects.py (29.7 KB)
Hi @phcreates
Very nice of you and thanks for providing a V7 file.
One thing that threw me at first is that the user has to specify a direction, with the default being cplane z. It would be nice to allow for the two other x and y cplane directions since z direction is limiting in perspective view. It’s great that you have a user direction option and one can click in another viewport to get z to be y in perspective view by clicking in front view.
In the file if one uses the z default option the projection fails in perspective view( to be expected since z is up and down axis and I want to project along x axis,
(“Project failed. The bounding box of the objects must fit within the target object edges in the projection direction. Try untrimming the target, or otherwise expanding it.”)
But if one clicks in front view it works, perhaps this might be confusing to some users and if you had x and y options and not just z in the cplane option the project could work in perspective view instantly without having to set a direction or clicking in front view.
Thanks for this improved plugin along with the depth option.
RM
projectFail.3dm (665.6 KB)
Ok, thanks for the feedback. I’ll take a look.
Actually, I see that the Project command just has one Cplane option (CplaneZ), so I think this script is consistent with that built-in command and should make sense to users.
Hi Peter,
Yes your right, I’ve always felt that the standard Rhino behavior should have had the other cplane options but that’s up to you to include or not and the direction option takes care of all that.
I’m really impressed with this plugin and I have yet to explore all those great options you included. I can see that this will very useful for modeling can’t thank you enough for your generosity and expertise and making this available for V7!
Here’s a quick test I did with fonts and chip board on a cylinder.
RM
