What method can I call on a GH.DocumentObject to update its presentation on the canvas?
I am trying to change all the input and output params of a group to override the IconDisplayMode (I work in icon mode but used named params for I/O). The Icon Display change is working, but the size does not update to the change until the param is moved.
How do I trigger the params to update their size? I’ve looked through the methods and properties on the IGH_DocumentObject Interface to no avail.
I haven’t - not successfully at least. Not sure where to implement that.
I did find a workaround, but it’s a kludge - ExpireSolution on the object does get the size to change, but it also recalculates the solution on that component, which is less helpful.
var grps = GrasshopperDocument.SelectedObjects().OfType<Grasshopper.Kernel.Special.GH_Group>();
foreach(var grp in grps){
var objs = grp.ObjectsRecursive();
var prms = new List<IGH_Param>();
foreach(var obj in objs) {
var comp = obj as GH_Component;
if (comp != null) {
prms.AddRange(comp.Params);
continue;
var prm = obj as IGH_Param;
if (prm != null) prms.Add(prm);
var incoming = prms.Where(p => p.Sources.Any(s => !prms.Contains(s)));
var outgoing = prms.Where(p => p.Recipients.Any(s => !prms.Contains(s)));
if (y == true)
foreach (IGH_Param p in incoming)
//Something here?
//tried p.OnObjectChanged(GH_ObjectEventType.IconDisplayMode), no luck)
p.IconDisplayMode = GH_IconDisplayMode.name;
p.ExpireSolution(true) //This works, but has unpleasant side effects
foreach (IGH_Param p in outgoing)
else
p.IconDisplayMode = GH_IconDisplayMode.icon;
Ok, now I also checked your actual code in the GH definition you uploaded.
All you need to do is after each p.IconDisplayMode change call p.OnAttributesChanged() - this triggers the necessary event. Flipping boolean input now will automatically update the icon display mode.
Ah I now realize that you are talking about the visual size of the component. For some reason I thought you were talking about the icon was not working properly.
Description: component for setting the icon display of inputs and outputs of a group on the canvas.
Instructions: select one or more groups and trigger the component to set the target group(s)
inputs are:
button which acts as a trigger, and a value list set to:
Value List “mode” set to: [Application = “0”, Icon = “1”, Name = “2”]
private void RunScript(object run, int mode, ref object A)
if (comp != null) {
continue;
p.IconDisplayMode = (GH_IconDisplayMode) mode;
p.Attributes.ExpireLayout();
