Update of the Desription of the Custom GH component
Hi @DavidRutten
I have noticed that Description field of the custom GH component is not updated after recompilation of the code.
Please refer to the picture below.
I am referring to the components that have been added to the GH file before latest compilation.
When I add a fresh component - change is visible.
Can you please have a look at this?
Thanks,
Dmitriy
Is that when you create a new instance of your component or load a file with an old instance?
Load old instance.
Yep, that string is deserialized, along with the name and nickname of the component. A case could be made that the Name and Description ought not be recovered from the file since they are non-editable fields, but at the moment this is the way it works.
