Is it possible to use update history in combination with blocks?
Specifically I have several dwgs that are constantly being edited in autocad.
I want to use them to keep an updated massing model in Rhino.
So far I have been able to import the dwgs from autocad into rhino successfully linking the files and have lofted surfaces from the curves with record history turned on. When I edit and update the files in autocad and reload them in rhino the block themselves update but it has no effect on the surfaces generated from those curves.
When I try the SELPARENT command rhino confirms that the surfaces are children of the inserted blocks.
Is what i’m trying to do possible?
Hello - my test above was with V6 - I made two blocks that include lines and lofted the lines, with History. I then edited the blocks (BlockEdit) - moved the lines - and on returning to regular Rhino, the loft did not change on its own but it did update on HistoryUpdate > All.
