Update height value with wall extend command
I noticed when I use wall extend command the height of walls extended not change in reference to effective wall’s height. See attached explain
height_issue_wall extend.pdf (841.6 KB)
Thank you
Hi @fn_a,
This is because extending a wall you can get results like this, where height is not equal along the wall:
Anyway, maybe we should display something different as a height value when this happens; I will propose this change for future versions.
