I have an input with 2 selectable values. In the definition, this will be auto-changed when the length of product entered is over a certain value.
So up to a certain length you can pick choice A or B, when over a set length the definition switches to choice B but the slider still shows choice A
Is there a way to auto switch the input parameter when product length dictates?
pavol
(Pavol)
2
Manipulating inputs is not allowed, see this Forum post:
Also, similar problem was discussed below and it could work for your use case:
Thank you, i will pass this on to our developer.
