Unwanted label on params - not from sunglasses
Can someone help me figure out how to get rid of this label on the left ?
It only appears on params when a custom name is entered, and disappears when “Display fullnames” option is enabled.
A plugin I installed must be responsible for this behavior, but I can’t figure out which one…
It is not from sunglasses plugin. You can see how sunglasses works with the divide curve component on the right.
Has anyone seen this before?
Thanks
SOLVED! Just found out it was Raven plugin that created those nicknames. Haven’t figured out how to turned it off yet. I will just uninstall the plugin for now and get back to this later on…
