Unrollsrf, keep dots with unrolled surface?
i very often take a large surface and split it up into sections so it fits on a sheet to cnc. after i split it i usually label them. typically it’s not a problem because the surfaces are planar. but when i have something like this i lose the labels because unrollSrf doesn’t keep text or dots.
am i missing something?
Hello - If you select dots at the prompt to select curves to unroll, they are accepted and go along as expected. Need a prompt tune up…
RH-62388 UnrollSrf: Prompt tune up
are you freaking serious! wow… so… many… hours lost :frowning:
