I need some help. Is there a sequence of tools in Grasshopper that could replace my current workflow? I have a surface bent in both directions, and right now I’m turning it into an unrolled surface (unrollSrfUV)… then I create additional surfaces and geometry on the newly created surface (the original unrolled surface remains unchanged). Once I have that, I use “Flow Along SRF” to wrap that geometry around the base geometry.
Could you give me some advice, please?
P.S.:Actually, I need to have a live transition before and after the “flow along srf” function.
unrollSrf isn’t available as standard tool in Grasshopper, so not to use a plugin I opted for UVCurve (dimensions)
becaus of 1 the projectced geometry aren’t exactly like in your file but from my experince this way is better and gives you wider control over the results
becasue of 1 you have to work on the untrimmed surface (original)
