I ran unrollsrf (not something I use frequently) and got this message:
Missing Dialog: the 18CUnrollErrorDialog dialog for this command is not yet implementedArea is 5.2928 sq inches (12.96 % ) smaller after unrolling
I’m not seeing that error here with Rhino 7.8 on Mac. Does it happen with a specific selection only? We may need the file and your SystemInfo results too. Thanks.
Here’s the file and my info.
Problem Unroll.3dm.zip (2.2 MB)
Another problem is the unroll results I get are quite bad. The surfaces I am trying to unroll (RED) are conical.
Rhino 7 SR8 2021-7-15 (Rhino 7, 7.8.21196.05002, Git hash:master @ 45c1fd6dc85c7c1cce8c0bbe6f3e16481ae9abfa)
License type: Commercial, build 2021-07-15
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 10.14.6 (Build 18G9323) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro15,1
Language: en-US (MacOS default)
AMD Radeon Pro 560X OpenGL Engine (OpenGL ver:4.1 ATI-2.11.26)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4 GB
Graphics: Radeon Pro 560X
Displays: Color LCD (258dpi 2x)
Graphics processors
Radeon Pro 560X (4 GB)
Color LCD (1680 x 1050)
Intel UHD Graphics 630 (1536 MB)
USB devices
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.8.21196.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 7.8.21196.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.8.21196.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.8.21196.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.8.21196.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.8.21196.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.8.21196.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.8.21196.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.8.21196.5002
Thanks, I can see the issue now with that specific model. I filed https://mcneel.myjetbrains.com/youtrack/issue/RH-65104 for future reference. It looks like the error is a UI issue only on Mac, you can click the Warning option when using UnrollSrf and change the choice from Dialog to Command Line and you’ll get the info about the deviation in the command line history instead of the error. Regardless though, the dialog should come up on Mac too. Thanks for the report.
In terms of UnrollSrf getting a better result with these conical surfaces, I’m not sure it can. The Squish command actually gets closer to the Area but I’m not sure if that result is useful for you.
I’d like to create a photoetch mask.
I am surprised it cannot handle this cone as there is a 1:1, onto transform between this and a flat sheet.
In fact, methinks what I am getting is a bug. The output surface is a total mess. Dupborder shows how bad it it.
UnrollSrf has a problem with the trimmed holes. This problem is much more significant than the difference between Windows and Mac in where the error message shows up.
Problem Unroll DC01.3dm (8.2 MB)
The surface was duplicated and all holes removed. The surface with the holes removed unrolls properly.
The original surface with the holes unrolled matches the surface with the holes removed when unrolled along the outer edges. The edges of the holes obviously do not unroll properly.
The edges were duplicated to create curves on the surface. When the surface without holes is unrolled the curves do no unroll properly.
UnrollSrf is not working properly with this set of trim curves.
@BrianJ The YouTrack item needs to be updated with this information or a new YT item created.
Rhino 7 SR9 2021-7-20 (Rhino 7, 7.9.21201.05001, Git hash:master @ 78eb9aea49a0504b0581ba2015526423539a4ed5)
License type: Commercial, build 2021-07-20
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 5-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.59
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-6-2021
Driver Version: 27.21.14.6259
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.9.21201.5001
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.9.21201.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.9.21201.5001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.9.21201.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.9.21201.5001
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.21.831\SectionTools.rhp “SectionTools”
