Unrollsrf based on selected seams?
Can unroll surfaces follow a selected unroll path?
For example, there are several ways to unroll a perfect cube. Is there any way I can select a certain set of cutting edges in order to get one specific result? Thanks
Hello- use UnjoinEdge first, to open the edges that you would like to be seams. it does seem like this could easily enough be part of the UnrollSrf UI,…
