as far as i understand is based on uv-coordinates. (parameter-space).
there is unrollSrfUV that might give a nicer base-Surface. (but its the u or v that will match, not the structure (number of CVs. knots, degree, …)
another approach is to rebuild the target Surface within needed precision to get uniform parameters / Knots.
there have been a few precision issues with arcs / cylinders - but i think this is fixed in rh9 (?)
Use UnrollSrfUV which preserves the parameterization and structure. (Corrected)
FlowAlongSrf needs the same parameterization; the structure does not need to be the same.
UnrollSurfUV was added in V5 and is the “old” UnrollSrf (prior to V5). The “new” UnrollSrf, introduced in V5, is designed to produce a more accurate shape with the tradeoff of changed parameterization and structure. UnrollSrf may also result in a polysurface.
