Can a texture be mapped onto an unrollsrf object? I mapped a texture on an object, after unrolling it the texture doesn’t show up.
Hi @Gee! Textures are applied Per Object or Per Layer.
If you applied the texture to the object, once you unroll it, you’ve created a new object to which you would need to assign the same material or texture.
If you apply the material / texture to the layer, than any object on that layer will inherit the material.
And dont forget _UnrollSrf _Explode=No
